Need help with LRP Z.28R
The problem is that the first bearing around the crank is letting the fuel out, and the backside pullstarter assembly too.
help me!
sorry about bad english.
help me!
My Feedback: (29)
TX
RE: Need help with LRP Z.28R
Hi,
This is a Gasoline engine forum. You would get a better response from the glow engine forum. Glow engines do not usually have crank shaft seals, so some leakage is normal. If it is excessive, the sealing areas in the crankcase are either worn or poorly machined. Glow engine are messy most of the time.
Dave
Dave
