Motor Idenification
IN
Motor Idenification
Setting up a plane for a friend. Plane was supposed to have a BME 50 in it. I pulled the cowl off the model and descovered this. Pretty sure its a "OLD" Brison from the brown case C&H module and looks like a cantalever crank. Looks like a Sachs cylinder with #447NIR on the base with letters W1 above it. Any clues for sure???
IN
RE: Motor Idenification
Hey Walt:
Call up Brison and get the new black carb insulator block.
The white nylon ones don't take the heat and can give you air leak problems.
From the horse's mouth.....
