New ZDZ-80
#701
My Feedback: (29)
RE: New ZDZ-80
ORIGINAL: airwayman
Don't want to get in a war with anyone but I would like to say I've had very good luck with RCShowcase. I'm very happy with my Super 80 as I am with my DA-100 and 3W-106. For those of you unfamiliar with how far the hobby has come in recent years, you need to fly a heavy, sloppily built, 33% plane with a Sachs-Dolmar 4.2 with a worn out or improperly set up throttle coupled spark ignition and be sure the prop has never been balanced. We're spoiled nowadays with reliability and power and I love it. Thanks Mike Dooley, thanks Dave Johnson and thanks Gerhard Skepskol? (that's close). Airwayman
#702
RI
RE: New ZDZ-80
im curious to know the needle settings some of you guys are running on the regular zdz 80 rv i just started mine up and i havent touched the neeldles yet they are still at 1 1/2 turns each . all im getting is like 5600 rpms . im just asking becuase my engine only has 4 tanks through it. i dont know if you guys are goin leaner on the high end or richer . any input would help thanks guys and by the way i had a problem with and engine and i called rcshowcase and i was mad at the beggining becuase i thought my sheared bolts were suppose to be waranty but then i spoke to mike dooley and he straightened me all out explained everything ,gave me half price to help me out and best of all I MAIDENED my 33& yak today ,,,, yeah baby
#703
RI
RE: New ZDZ-80
im saying becuase i can tune a glow engine with perfection i just dont know if there is something in gas engine i should take differently. i had three more flights today with the 33 % yak and the zdz 80 rv and the ngine kept getting stronger with every flight.
#706
RE: New ZDZ-80
reminds me, are you still running 32:1. if the plug is fouling, time to go to 40:1 I did that at 4 tanks, and went to AMSoil dominator at 40:1 and it transformed the motor into a monster in one flight with no more heating than before. The engine began to loosen up nicely. good reminder Mr Bigg.
#707
RI
RE: New ZDZ-80
hey goosef thanks for all your replies man i apprecciate it. i have 5 tanks through the engine at 32:1 using mobil synthetic 2t for aircooled engines.i only tached it once during the second time i fired it up. i will tach it again this weekend . i just dint know if you guys were leqning the high end at all to get top rpm .. thanks
#708
RE: New ZDZ-80
richen low, lean high, 1/8 turn each, use 40 to 1, try that, then get the transitions smooth and responsive, then slowly lean the top. If you take the top more than 1/4 turn, open the low, a smidge. keep it 500 below max rpm on the rich side.
what prop?
keep the motor under 7500 in general, but dont load it heavily. Use the mixture to control it from there while you break it in. Once you get the low end right, dont mess with it. At some point, you will hear it kick in another level as it loosens up fully. It will act like you added a gear. When you land, the prop will flop freely back and forth, Its mostly broken in then. Stay with the 40:1 and dont be temped to go leaner. I got that directly from Mike. after awhile, take the spark plug out, clean it with a toothbrush, and alcohol or lighter fluid, and check gap. I dont remember the gap for the older 80. call zdz if you need to.
When you switch to leaner oil mixture, it will blow a bunch of black soot out of the motor. no problem, its just getting the muffler hot, and blowing the crap out so it will make power. the difference was astounding when the power came on, simply astounding. Be patient. i only got about 5600 rpm on my super 80 at first with a 26x10. Now its up over 6000, havent checked it in awhile.
what prop?
#709
RE: New ZDZ-80
Hi Guys...
I was going to take the spark plug out of my ZDZ 80 RV-J but it won't come out, although I haven't really reefed on it yet.
Before I do any damage, does anyone have any tricks.
This engine has yet to be run.
I'm using the spark plug socket that came with the engine then using another 1/2 " drive socket over it with a rachet(lots of torque).
This is a right-hand thread on these plugs is it not?
Also, I tried tightnening a little first but it doesn't move either.
Do they make a better plug socket that will fit inside the heat sink/resistor piece?
Should I get the impact wrench on it to try and rattle it loose?
Any ideas would be great.
Cheers,
Lyle
Cheers,
Lyle
#710
RE: New ZDZ-80
ORIGINAL: dptp9lf
Hi Guys...
Any ideas would be great.Lyle
Hi Guys...
#711
RE: New ZDZ-80
You're right Airwayman... There is probably no need to remove the plug... the Curious George syndrome was taking over at that point
I'll run it and leave it alone until I need to cross that bridge in the future.
Anyway, speaking as a highly experienced plug remover from my past careers and racing days, I've removed a lot of spark plugs from some pretty intense alloys and ran across some stubborn ones as well. I always used a 3/8" impact wrench and seldom failed. This being a foreign made engine, my main concern is that for some strange reason they would put a left hand thread on it. I know it's a pretty standard plug but you never know.
The engine is still on the bench so giving it pop like you suggested is a little cumbersome.
I'll get the engine mounted and running and when I need to remove it, I'll have the engine more secure and the old "quick pop" method should work just fine.
Also, I'll get me a high-quality plug socket rather than the cheesy one they send with the engine. Biggest problem there is getting one to fit inside the heat sink/resistor piece thingamajiggy?
Thanks for your reply,
Lyle
Lyle
#712
RE: New ZDZ-80
use a thin wall socket and it will take over 20 ft lbs to bread it loose - which is too tight in my book
with everything clean and cool and dry - 15 ft lbs is fine.
rattle wrenches are noit a great idea on this stuff--
#713
RE: New ZDZ-80
Thanks for the info Dick!
I was out looking for a thin wall socket today but they're a little hard to find. I think Snap-On or Mac will have something.
You're right on the rattle wrench thing... that would just be a last resort and of course I would have to plan on replacing the plug. I really don't think it would come to that anyway.
I have a torque wrench that I'll use when I do re-install the plug.
Anyway, first things first, we need to git her running and broken in!
Cheers,
Lyle
Cheers,
Lyle
#714
RI
RE: New ZDZ-80
thanks goosef ur a true rcER thanks for all the help thats what im getting right now 5600 exsactly im running a 26 1o pt models carbon fiber prop today i got two more flights in but spent most of the time fixing stuff that kept happening . tomorrow i will leave the cowling off and try to get a little more rpm. i also built a bafle inside my cowling since my 33% yak cowling covers the whole head now it has a bafle that directs air right over the cylinder head. oh and by the way i switched to 40 to 1 today and yes there is a lot of that black stuff coming out i noticed today. my 33 % sd yak is awesome i was doing knife edge take offs today followed by right side up snap rolls to hover it was awesome. i've been flying since last august goosef and i picked it up real quick i've had about 6 planes before i jumped into giant scale . i crashed all of them trying stupid stuff close to the ground but im not taking any chances with this beauty... and plus my buddy mark at the field has helped me a ton since he has been flying gas for a while now . he has a hanger 9 27% 260....... again thanks goosef
#716
RE: New ZDZ-80
it will fly it - --the question is , wha type of performance are you after? - up hyre at 4350 ft it takes a pipe version well setup on a 27x10 to get really unlimited performance on big heavy models - if that model were mine --it would get the early style 160 on in cowl mufflers light strong n a little noisy but a great combo.
#717
RE: New ZDZ-80
ORIGINAL: dick Hanson - if that model were mine --it would get the early style 160 on in cowl mufflers light strong n a little noisy but a great combo.
#718
RE: New ZDZ-80
the more power available - the more slowly you can fly the model -if weights remains the same . this is why my favorite engine for these so called 100 sized planes is the light ZDZ160 (early model ) low weight gain huge power gain.
#720
RE: New ZDZ-80
ORIGINAL: my favorite engine for these so called 100 sized planes is the light ZDZ160 (early model ) low weight gain huge power gain.
#721
RE: New ZDZ-80
Hi...
Can I remove the Idle adjustment screw on the Tilotson carb? It's ok where it is but I just wanted to clean it up a little. I will investigate myself but I'm closer to my computer than the engine at this moment.
Cheers,
Lyle
Cheers,
Lyle
#724
RE: New ZDZ-80
ORIGINAL: Mike Dooley/RCS
Lyle,
The front outlet T-70 or T-80 silencers simply kill engine performance on a long wraparound header, by almost 600rpm. The new TR-80 is a far better choice if the engine is inverted.
If the engine is going to be mounted horizontally and a short header is used, then the front outlet T-80 silencer would work, but even then, the new TR-80 would still have the best performance. We are thinking of discontinuing the T-70 and T-80 because the TR-70 and TR-80 are just that much better.
An exit air opening with a spoiler in the fuselage towards to back half of the silencer is needed anyway for proper cooling, so the rear outlet design is really not a problem.....
Lyle,
I have the Wraparound pipe and TR80 ordered but it's back ordered. Do you happen to know the measurment from the exaust port to the back of the silencer with this set-up so I can plan a little closer on space needed?
Of course anyone else that knows can chime in as well.
Cheers,
Lyle
#725
My Feedback: (42)
RE: New ZDZ-80
Is anyone using one of these engines on a Pacific Models 35% extra or have an idea of header needed for a pipe or if I don't modify for pipe a performance cannister?
Richard
Richard
