ZDZ 80 TROUBLE
My Feedback: (19)
VA
ZDZ 80 TROUBLE
This is a brand new engine //never run...........
First would not start at all...reset timing cured the problem under choke...But now needs to be sloppy rich to start ( pull the engine thru like 20 times) I will fire without the chocke at that point but will not idle at all ....Seems like it is just burning the prime out of the carb..Runs 5-7 seconds and dies......
Fuel seems to be drawing .....Low end needle is a 2 turns out....I have checked that the intake gasket is turned corretly.........ANY BODY GOT ANY THOUGHTS ..
Ignition battery is 4.8 volts fresh charged.......
NJ
RE: ZDZ 80 TROUBLE
Check the throttle plate I think the head of the screws should be pointing in, if you took the throttle arm off to replace it that could be the problem.
My Feedback: (19)
VA
RE: ZDZ 80 TROUBLE
Screws are facing inward........I'm noticing a leak in the carb around one of the plates...Just a single drip on gas when choking....I've tried to seal with a small amount of form a gasket....still leaking...
This is a new engine....total run time about 25 seconds..... Does anyone know the model number for this walbro....Perhaps I could pick up a new gasket......I'm really hoping to fly this weekend...I hate the thought of having to send this back to RC showcase........THANKS FOR ANY INPUT....I've read ALOT of the posts under zdz 80 search looking for similar problems
My Feedback: (41)
RE: ZDZ 80 TROUBLE
I haven't even tried starting my new 80 yet, but the 50 I got recently (it is a low time used engine, and my first gasser) drove me nuts with the same problem. I found that it just really needs to be sloppy rich to start, and it will not play if the low speed needle is not close to three turns out. It will start with that needle closed more and idles smoother, but it will not cover the transition from idle to high power settings if it's leaner.
I fought that thing for a couple of weeks, timing, new sparkplug, different ignition, different fuel/oil mix, throttle plate check, pulled the carb screen, base gasket, etc. and I just couldn't get it run in any other way than the low speed needle further out. The high speed needle is about 1 1/4 out since the altitude here is about 4500 ft. above Sea Level.
I finally took it up to Dick Hanson and he told me set the needle valves where it works and in the case of my 50, it had too big a prop on it. So smaller prop for this engine, richer low speed needle settings and it starts really nice, covers the transition with no stumbles and will wind up like it's supposed to. It might be worth a try...
