EI Conversion for 32
Old 10-31-2005 | 01:10 PM
My Feedback: (106)
Default EI Conversion for 32
Is there a conversion kit to convert the 32 to electronic ignition like there is for the 50?
Old 11-03-2005 | 12:22 PM
Bax
Default RE: EI Conversion for 32
The conversion's not easy. Not only do you need the electronic parts, you need a new crankcase...the old case doesn't have the mounting bosses. Basically, it would cost you as much as a new EI engine if you just bought the parts. It's really not worth the expense to convert your engine.
