KILL SWITCH ON ZENOAH G 38!!!!!!
I GOT A USED ZENOAH G 38 RECENTLY BUT IS UNCERTAIN WHERE TO HOOK THE WIRES FOR A KILL SWITCH, I AM LOOKING AT IT NOW AND THERE IS A PIECE OF BLACK WIRE AT THE BOTTOM OF THE CAPACITOR AND A RED WIRE ON A SPADE , HELP!!! PLEASE.
The stock magneto coil (capacitor ?) on a G38 has a black wire at the top, soldered to a lug that goes inside the coil...You can solder a wire to this connection to ground the engine...Any other wires you see on the coil were added on by a previous owner...
MI
Mine is like a loop back to the coil. Do you just solder to the loop? Or do you cut one side off and solder it?
This is a used engine and I would like to add a kill switch to it.
Bill
Bill
