Ignition switch for the DA 50 R
What are you using for the ignition switch on the DA 50? I have a new Futaba switch for a reciever that I was going to use but it is not the Heavy Duty one , will the switch work or should I get something different?
My Feedback: (41)
http://www.smart-fly.com/Products/Ignition/ignition.htm (see bottom of this web page).
Use the Cermark or JR HD switch (same thing). It's perfect for an ignition and I just put one on my DA 50. You need to cut off the ignition side plug of the switch and solder on DA's HD ignition power connector/leads. I used a Dean's Ultra connector on both sides of my switch and did not use DA's. I like Dean's better.
PS: DA does not recommend standard switches, they need to be HD. I called them.
My Feedback: (16)
KY
I've got two Da-50's and use the MPI HD switch with charge jack and they work fine.Dean connector are a good heavy connector that are gold plated and can take the heat well.Heat shrink them together to make sure they stay togerther.
