JMB Muffler with a DA 100
NJ
Has anyone had the opportunity to use a pair of 60/60/270 JMB mufflers with a DA100 what results did you get? did it cost any power with that small a muffler. I need to decide what to use have very limited space in my new project PA 35% extra.[sm=drowning.gif]
Any help would be appreciated.
IF-you use really short header -like 4-5 inches - it should be OK-BUT-I have not tried em on the DA- on the 50cc ZDZthey work quite well - little if any loss- just get the shortest setup possible.
IN
A buddy has a DA-100 using those model mufflers in a Wildhare Extra. His engine is down a couple of hundred rpm from the standard in-cowl mufflers from DA.
NJ
Diablo-RCU
Do you know what the RPM numbers are and with what prop.
IN
ORIGINAL: Mrt1750
Diablo-RCU
I can't remember what he was running last Summer, but it was T-Bob (on RCU).
Diablo-RCU
