How do you check for COMPRESSION?
Old 01-05-2006 | 08:18 PM
Default How do you check for COMPRESSION?
How do you check for compression on a gas engine and what do you need to do it? Thanks...
Old 01-05-2006 | 08:33 PM
Antique's Avatar
Default RE: How do you check for COMPRESSION?
If the engine uses 14mm spark plugs you can get a cheap compression tester at an auto supply store..Crank it with a starter...For a reference and G62 will show about 115 PSI with the cylinder dry and about 150PSI if you pour a little motor oil in the spark plug hole first...
Flipping by hand will show lower numbers...
If the engine runs well who cares ?
Old 01-05-2006 | 08:41 PM
Well it is a McCulloch 28cc weedwacker engine that I am about to convert for RC use and want to make sure it is ok before I spend the time to do it. It did run prior, but it didn't feel like it had as much power as it should have, at least that is the way I felt it. When I took off the back plate to expose the piston area and turned it over by hand, I heard air seaping by the piston, not sure if this is right or not. Does anyone know what kind of compression I should be getting with this engine? Thanks...
Old 01-05-2006 | 08:50 PM
Antique's Avatar
It's not physically possible to completely seal the compression, so most engines will sound like that when turned over...Check the conversion forum, someone there might know..
Old 01-06-2006 | 12:46 PM
OK, Thanks...
