MVVS/Evolution 45 bolt pattern/spinner
Does the bolt pattern of the Evolution/MVVS 45 match the pattern of the 3W engines?
I was thinking in terms of Spinner selections etc.
My Feedback: (76)
Nope, you are going to need a piece of stock aluminum; take the washers with you to a machine shop and ask them to make you a drill jig. The shaft width on it is 10 mm or 1 cm.
Too bad... as far as I can see Truturn only makes spinners with light backplate for DA and 3W...
Guess I have to find something else then.
