Engine rebuild question
Old 01-13-2006 | 02:58 PM
TooLy's Avatar
Default Engine rebuild question
HI,
I need to do overhaul to my zenoah 23cc, I ordered a new cylinder,piston, ringand what else needed.
My question is, when I istall the new cylinder over the piston with ring, I just need to compress the ring with the fingers so the cylinder will go over it ?
Thanks.
Old 01-13-2006 | 04:59 PM
L48's Avatar
L48
Default RE: Engine rebuild question
Yes the bottom of the cylinder has a slight taper to help the ring go into the cylinder. I'm not sure, some pistons have a pin in the ring grove so the ring will only go on one way, look for that. It may not have the pin, in that case no problem.
