Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 ZDZ ignition wire- can this be fixed? >
Old 01-15-2006 | 10:30 AM
My Feedback: (12)
Default ZDZ ignition wire- can this be fixed?
I destroyed my favorite plane the other day and was doing an autopsy yesterday and found the igition wire torn off where it goes onto the spark plug. Can this be put back on or am I going to have to buy a new ignition? Thanks. Rusty[img][/img]
Old 01-15-2006 | 11:17 AM
JoeAirPort's Avatar
My Feedback: (41)
Default RE: ZDZ ignition wire- can this be fixed?
I'd replace it. That doesn't look like it would repair too easily. That shield keeps RF noise from getting into your radio gear, if it's compromised it could cause lots of RF (and hence another crash).
Old 01-15-2006 | 01:13 PM
coony2787's Avatar
My Feedback: (33)
Send it back to ZDZ and let them just put a new spark plug wire on it .
Chad
Old 01-15-2006 | 02:55 PM
Bob Laine's Avatar
My Feedback: (91)
WHAT COONY2787 SAID.
Old 01-16-2006 | 11:11 PM
My Feedback: (16)
I had a similar problem with my wire. They told me they can't fix it and have to buy a new one.
Smokey
Old 01-16-2006 | 11:16 PM
My Feedback: (12)
Do I have to buy an entire new ignition? The other end doesn't seem replaceable either. Rusty
Old 01-16-2006 | 11:40 PM
My Feedback: (16)
I had to buy the whole thing
Smokey
Old 01-17-2006 | 01:43 AM
tkg
FWIW, CH Electronics ignitions are made and REPAIRED right here in WY. Leads are a common replacement item. RC ignitions are made and REPAIRED in AZ.
Old 01-17-2006 | 10:07 AM
Antique's Avatar
If the ignition is OK and the wire that plugs into the box is OK, a 3W or DA cap will repair the spark plug end....don't know what they cost, somewhere around $20.....
Old 01-17-2006 | 10:21 AM
rmh's Avatar
rmh
except that the spark plug is a smaller size.
woops!
I have done that mod with acyl head insert from Terry at CH ignition and the smaller plug-------- works just fine.
Old 01-17-2006 | 10:44 AM
Antique's Avatar
OOPS..Yup, forgot...With the adapter from TKG and the CM6 spark plug it will not come off like the original with the setscrew or hose clamp, and you don't have to cut the top off the spark plug....
