Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Spiral Cable Wrap on Spark plug wire >
Old 02-06-2006 | 11:03 AM
shakes268's Avatar
Default Spiral Cable Wrap on Spark plug wire
I know a lot of people use this stuff on their spark plug wires to keep the shielded cable from wearing through.
Has anyone had a problem with this stuff being effected by heat? I'm worried mine may be too close to the muffler and will melt if it gets too hot.
Old 02-06-2006 | 02:11 PM
Default RE: Spiral Cable Wrap on Spark plug wire
If you're concerned about the wrap, you should be doubly concerned about the plug wire itself. Keep those items at least an inch away from the muffler any way you can.
Old 02-06-2006 | 07:42 PM
My Feedback: (13)
I use the split plastic cable guard. I cannot find the spiral type anymore. The kind I use is "ringed", but it has a split the entire length of the tubing. It is easy to slide over the plug wires to protec tthem. I use a tie-wrap at the end on the plug to keep it in place. It does not get anywhere near the exhaust and has never melted.
Old 02-06-2006 | 07:49 PM
Josey Wales's Avatar
My Feedback: (61)
ORIGINAL: DMcQuinn
same here
Old 02-06-2006 | 10:45 PM
The trade name of the split plastic stuff is "loom". It works out just fine.
Old 02-07-2006 | 12:31 PM
My Feedback: (14)
ORIGINAL: DMcQuinn
Radio Shack has spiral wrap in just the right size.
http://www.radioshack.com/product/in...tId=2062665&cp
Old 02-07-2006 | 02:41 PM
shakes268's Avatar
Yep, the radio shack stuff is what I bought. It fit great, had a lot left over for other uses.
Old 02-07-2006 | 05:47 PM
My Feedback: (61)
ORIGINAL: shakes268
Yep thats what I have also
Old 01-04-2012 | 09:27 PM
If you are looking for cheap priced and durable spiral wrap for home and vehicular use. Online stores like http://www.cabletiesandmore.com/ offers lots of products where you can choose from.
Old 01-04-2012 | 09:39 PM
w8ye's Avatar
My Feedback: (16)
I've been buying the spiral wrap from Tower
Old 01-04-2012 | 11:28 PM
My Feedback: (38)
I found my spiral wrap at O'reillys auto parts. - Tim</p>
Old 01-05-2012 | 04:37 AM
a1pcfixer's Avatar
My Feedback: (7)
Also;
Outlaw Hobby Products
http://outlawhobbyproducts.com/wiring/wire-wrap/
Old 01-05-2012 | 05:39 AM
Timber29's Avatar
Mcmaster-carr
http://www.mcmaster.com/#catalog/117/800/=fo8lo3
Old 01-05-2012 | 06:51 AM
<table id="RenderableTbl_634613499512265421ABNJ" class="ItmTbl"> <tbody> <tr> <td class="ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1,2" style="padding-left: 0px; padding-right: 16px"><span class="Fraction">5/8</span>" to 2"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpecBefrPartNbr ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1,2" style="padding-left: 0px; padding-right: 13px">0.010"</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1">1459T17</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceHorizPivotBefrPartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 13px; padding-right: 22px">13.64</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="2">1459T27</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceTblEnd ItmTblContentCell NoWrapCell" data-mcm-prodgrps="2" style="padding-left: 13px; padding-right: 5px">88.28</td> </tr> </tbody></table><div id="Sub_8973099016932" class="PrsnttnStructure5"><div><div id="PrsnttnHdrCntnr_634613499513827821UWIU" class="Prsnttn_SubHead smallVerticalGutter SuperLbl"><span>Woven</span></div><div><div class="ImgsCntnr verticalGutter"><table class="ImgGrid" style="table-layout: fixed"> <tbody> <tr> <td style="width: 91px"></td> </tr> <tr> <td class="GridCell ImageCell" style="padding-left: 0px; padding-right: 0px; padding-top: 0px"> <div class="ImgCaptionCntnr" style="width: 91px"></div> </td> </tr> </tbody></table></div><div class="CpyCntnr verticalGutter" style="width: 330px"><p class="PrsnttnCpy">Woven sleeving provides better abrasion resistance and is flame <span class="Wrd">retardant.</span> Meets ASTM <span class="Wrd">E162.</span> Temperature range is <span class="Wrd">-58&deg;</span> to <span class="Wrd">+257&deg; F.</span></p></div><div class="ItmTblCntnr PrsnttnTbl"><div class="ItmTblGrp"><table id="RenderableTbl_634613499512421661GZTK" class="ItmTbl"> <thead> <tr> <th class="ItmTblColSuperHdrAlign"></th> <th class="ItmTblColSuperHdrAlign"></th> <th class="ItmTblColSuperHdrAlign"></th> <th class="ItmTblColHdrEndPrice ItmTblColSuperHdrAlign ItmTblColSuperHdrDeflt" colspan="2" style="padding-left: 3px; padding-right: 5px"> <div class="ItmTblSuperHdrCell"> <div class="ItmTblColHdrBracket"><span class="ItmTblColHdrBracketTxt"><span class="Wrd">3-ft.</span> Lengths</span></div> </div> </th> </tr> <tr> <td class="ItmTblBaseHdrBorderCell ItmTblColBaseHdrNoPivotIndent NoWrapCell" style="padding-left: 5px; padding-right: 10px">ID</td> <td class="ItmTblBaseHdrBorderCell ItmTblColBaseHdrSpecInterior NoWrapCell" style="padding-left: 0px; padding-right: 10px">Bundle <span class="Wrd">Dia.</span>
Range</td> <td class="ItmTblBaseHdrBorderCell ItmTblColBaseHdrSpecInterior NoWrapCell" style="padding-left: 0px; padding-right: 10px">Wall
<span class="Wrd">Thick.</span></td> <td class="ItmTblBaseHdrBorderCell ItmTblColBaseHdr NoWrapCell" style="padding-left: 0px; padding-right: 10px"></td> <td class="ItmTblBaseHdrBorderCell ItmTblColBaseHdrEndPrice NoWrapCell" style="padding-left: 0px; padding-right: 5px">Each</td> </tr> </thead> <tbody> <tr> <td class="ItmTblCellIndentPivotNone ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell ItmTblDigitAlignX1 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 5px; padding-right: 15px"><span class="Fraction">3/16</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 15px"><span class="Fraction">1/16</span>" to <span class="Fraction">3/16</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpecBefrPartNbr ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 12px">0.024"</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1">2649K51</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceTblEnd ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 9px; padding-right: 5px">$6.19</td> </tr> <tr> <td class="ItmTblCellIndentPivotNone ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell ItmTblDigitAlignX1 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 5px; padding-right: 15px"><span class="Fraction">5/16</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 15px"><span class="Fraction">3/16</span>" to <span class="Fraction">5/16</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpecBefrPartNbr ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 12px">0.024"</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1">2649K52</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceTblEnd ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 9px; padding-right: 5px">7.56</td> </tr> <tr> <td class="ItmTblCellIndentPivotNone ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell ItmTblDigitAlignX1 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 5px; padding-right: 15px"><span class="Fraction">1/2</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 15px"><span class="Fraction">5/16</span>" to <span class="Fraction">1/2</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpecBefrPartNbr ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 12px">0.024"</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1">2649K53</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceTblEnd ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 9px; padding-right: 5px">8.72</td> </tr> <tr> <td class="ItmTblCellIndentPivotNone ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell ItmTblDigitAlignX1 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 5px; padding-right: 15px"><span class="Fraction">3/4</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 15px"><span class="Fraction">1/2</span>" to <span class="Fraction">3/4</span>"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpecBefrPartNbr ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 12px">0.024"</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1">2649K54</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceTblEnd ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 9px; padding-right: 5px">11.17</td> </tr> <tr> <td class="ItmTblCellIndentPivotNone ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 5px; padding-right: 15px">1"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 15px"><span class="Fraction">3/4</span>" to 1"</td> <td class="ItmTblCellSpec ItmTblColSpaceSpecBefrPartNbr ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 0px; padding-right: 12px">0.024"</td> <td class="ItmTblCellPartNbr ItmTblColSpacePartNbr ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1">2649K55</td> <td class="ItmTblCellPrce ItmTblColSpacePrceAftrPartNbr ItmTblColSpacePrceTblEnd ItmTblContentCell NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 9px; padding-right: 5px">12.78</td> </tr> <tr> <td class="ItmTblCellIndentPivotNone ItmTblCellSpec ItmTblColSpaceSpec ItmTblContentCell ItmTblDigitAlign0 NoWrapCell" data-mcm-prodgrps="1" style="padding-left: 5px; padding-right: 15px">1 <span class="Fraction">1</span></td> </tr> </tbody></table></div></div></div></div></div>The Carr site
