gas engines
Old 02-12-2006 | 10:22 AM
Default gas engines
What is a good prop size for a quadra 50? Is there an easy way to tell a 50 from a 52 without pulling the head off to look at the piston?
Old 02-13-2006 | 07:21 AM
Default RE: gas engines
YSUSER,
You get into this gasser, you going to change your user name?
The Quadra 50 or 52 will probably work well with a 20 x 10, or 20 x 12 at least to start with. Someone else will have to say how to tell them apart.
Have fun!
Bedford
Old 02-14-2006 | 11:27 PM
Is there an easy way to tell a quadra 50 from a 52 without pulling it apart?
Old 02-16-2006 | 10:09 AM
My Feedback: (75)
The easiest way to tell the difference between the Quadra 50 and 52 is to measure the exhaust port width. The 50 is under 1 inch and the 52 is over one inch.
Old 02-16-2006 | 10:48 AM
My Feedback: (16)
I would recommend using a 20x8 to get the RPM's up.
