Engine Identification Gas 4.2?
Old 02-15-2006 | 02:16 PM
Default Engine Identification Gas 4.2?
The wife of friend who is gravely ill has asked me what the value of some of her husbands stuff is.[]
He has an engine that I believe that someone told me was an early Brison 4.2. On the rear of cylinder head is: 49 ZN4W1 MAHALE. It has a 6 bolt hub and also an adapter to convert to single bolt hub. It has a C@H green box electronic
ignition. The timing ring is white and 1.5 inched deep with a rounded edge towards the front. It also has a Walbro
carb. I have also been told it could be a Sach's,Walker or an Q&M engine.
I would appreciate any help you could give me on type and possible value of this engine.
Skylark
ID:	408693   Click image for larger version
ID:	408694   Click image for larger version
ID:	408695   Click image for larger version
Old 02-15-2006 | 02:26 PM
TLH101's Avatar
My Feedback: (90)
Default RE: Engine Identification Gas 4.2?
Based on the timing ring shape, and the machined recesses on the front of the case, it's a Walker 4.2.
Old 02-16-2006 | 01:26 PM
Thanks Terry,
Do you know if Walker is still in business or any history behind Walker.
I have seen a chart of engine/prop/rpm data that said: Sachs Walker 4.2 68 Bolly 24 10 7000.
Sachs as the manufacture and Walker 4.2 as the model of engine.
See link http://www.rcfaq.com/rpmstats/rpmbycc2.htm
Again thanks for your help,
Skylark
Old 02-16-2006 | 02:11 PM
BBW Walt's Avatar
ORIGINAL: skylark-RCU
Thanks Terry,
Skylark
If memory serves me correctly, Walker Machine was bought up by Precision Eagle. This happened several years ago. Precision Eagle is now Planes Plus. I'm sure a call to Carla would answer any questions about the Walker 4.2
Old 02-16-2006 | 11:47 PM
T-one's Avatar
Precision Eagle did buy some of the Walker stuff and called the engine the eaglet. I believe it was the 50cc size. Some years back Precision quit making them as well.
Old 02-21-2006 | 10:59 AM
Hi all,
Just to let you all know, I saw Carla at a swap meet in Davenport,IA this weekend.
She confirmed that Precision Eagle did buy out Walker. She is now the sole owner of Planes Plus and has parts to fix Walker engines if you need them.
Thanks to everyone for all of your help,
Skylark
