Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Multi-bolt hub for BME 110 - where??? >
Old 03-06-2006 | 04:54 PM
bodywerks's Avatar
Default Multi-bolt hub for BME 110 - where???
I have heard rumblings of people putting a multi-bolt hub on some of their older 110's, but have not heard about where to get them. I have a brand-spankin' new 110 that is the version just prior to their latest, which already includes the multi-bolt hub and a 10mm shaft. I really am not comfortable with the single-bolt, especially for CF props, so I want to change it out.
Where do I get this hub??? I have tried contacting BME with ZERO success, so I don't know if it is them or someone else that carries it.
Help me out guys!
Old 03-06-2006 | 08:13 PM
bodywerks's Avatar
Default RE: Multi-bolt hub for BME 110 - where???
uh, bump.
Old 03-06-2006 | 11:53 PM
RTK's Avatar
RTK
Actually I have not had any problems with the single bolt/nut hub. Just make sure it is good and tight, really tight. A carbon prop would even be better, that way you do not sink the washer half way thru the softer wood props.
Old 03-07-2006 | 12:01 AM
Modified's Avatar
I've had no probs with the single bolt hub, but I did bolt the spinner back plate to the hub with the two socket head screws and counter sank them into the prop.
Old 03-07-2006 | 03:17 AM
bodywerks's Avatar
Thanks. Are you running a CF prop?
Old 03-07-2006 | 09:18 AM
Since I started really tightening the prop nut, I've had zero problems with slippage, and I've used both Mejlik and Biela carbon fiber props. It's helpful to use a spinner that has good knurling on the backplate to hold the prop (like a Tru-Turn). I use Dave Brown spinners that has very shallow knurling, so I also fold a piece of sandpaper in half with the rough side out and maybe 2" square, and put that between the backplate and prop and tighten that down with a socket wrench (TIGHT!).
ZERO slippage.
Old 03-07-2006 | 09:34 AM
bodywerks's Avatar
Well, I'm bolting this engine to a Yak and may want to do away with a spinner. I just think the multi-bolt would not only look better, but be better.
Old 03-07-2006 | 10:24 AM
Modified's Avatar
I have ran both, BME 27-10 wood and a Mejzlik 28-10 carbon. Neither have slipped.
Old 03-16-2006 | 07:16 PM
My Feedback: (16)
I have used drywall sand paper as backing for the spinner (dave brown) works great!
Old 03-16-2006 | 10:13 PM
Fancier in this case is not better. A single bolt hub works just fine, and when the prop is spinning it's kinda hard to count the bolts.
Old 03-16-2006 | 10:19 PM
Antique's Avatar
Our 30 hp 289 twin racing engine has 3 bolts holding the prop on...A 3/8x24 center bolt and two 1/4x20 anti rotation bolts...It would work (and has) with only the center bolt when the other two got loose when we forgot to check between rounds...If it had been a 6 bolt hbu without the center bolt the 6 would have sheared off and the plane would have been destroyed...As it happened the center bolt got tighter when the other 2 sheared...NO six bolt hubs for me......
A 3/8x24 grade 8 center bolt will hold ANY prop on ANY rc airplane ever made...
The key word is TIGHT..
The prop was a CF 21x28 turning at 9000 rpm....
Old 03-17-2006 | 05:09 AM
bodywerks's Avatar
Thanks guys. The conversation is over. I already sent the engine to Kieth and had the mod done and got it back. The other real nice thing about it is I won't have to worry about perfectly drilling the center prop hole every time...it's knida hard to fing a 10mm-7/16" step reamer around here, or anywhere!
