I think it's a Webra
Old 12-11-2002 | 08:37 PM
Default I think it's a Webra
I have acquired a gas 2 stroke engine that has a webra spark module connected to the back of the engine with some type of sensor or pick up . Is there anyone who has had an engine
with this type of setup ? I need info as the ignition dos'nt work
Bob
Old 12-11-2002 | 08:59 PM
Antique's Avatar
Default Webra Bully
Webra Bully, Best power for its size(still) made many years ago..The ignition sensor magnet is embedded in the crankshaft web and the sensor screws into the case at the rear...Never tried to use the ignition, most were glow....Best bet is to have it converted to a newer ignition, or get a G23 glow carb and make it a glow engine....
Old 12-12-2002 | 01:55 PM
rcign
Thanks for the info. I will check out other ignitions
hatman
