Webra Bully Questions? Pls Help
#78
My Feedback: (84)
WI
RE: Webra Bully Questions? Pls Help
You have a nice looking Webra like it has very low run time. B&B has a chock plate for that carb. Any two-line tank setup will work. Just insert a T in the carb line and run that to the side of cowl and add a fuel dot. This is for filling and draining the tank.
This line would be capped in flight. The vent line will go to the firewall and exit out the bottom. For 3D most guys will run a vent line but make a loop on top of the tank and cable tie it in place. This helps fuel draining out. Use silicone fuel tubing.
#82
my bully is still inconsistant as far as running good in the air it runs great on the ground and any rolls or loops it will always cut out to where i have to pull the throttle back or it will die on me and it likes to spudder while in the air and when it doese it spits out little puffs of white smoke any suggestions
#84
My Feedback: (84)
WI
bigbadassredhead
I would try to add the brass tube to the air breather plate and run a silicon tube into the fuselage. But I think …………..
Your engine looks new and will need to get some time on the ring before it runs good. The glow fuel may be a problem, what are you using for oil content? The Webra will need the same fuel as the big Supertigere engines, lower oil content.
Webra recommended 5% synthetic oil (like KLOTZ-200 at 5%) with 5% nitro. Some fuel suppliers have a Supertiger blend that will work.
The engine is also sensitive to it’s exhaust, may like a pipe.
#85
so my fuel has 25% on the bottle that % is the nitro right the oil % is not disclosed on the bottle?
when i'm running full throttle the motor seems to surge what would that be??
#87
My Feedback: (84)
WI
Stock 25% nitro fuel has about 16 to 18 % oil or more. I used to use the Supertiger blend fuel with out a problem. The pumped carb diaphragm may be bad just from old age. This engine is from 1980’s and if the old owner ran it once it will need a carp cleaning. You must have a diaphragm for methanol. May find a kit at a local Go Cart shop. Look for how to clean the carb on RCU. This engine is also sensitive to muffler backpressure and likes to run on tuned pipes (on glow fuel). Still could need break-in time on the rings. This is as far as I can help. I would start with the fuel first then the glow plug (cold or everycold). Good luck.
You may want to check out www.rcignition.com and post a question to Ralph on his site.
#88
3dsky 1 more ? my aileron servo on 1 side of my wing keeps breaking gears and it will only do it when i apply my electric starter to the motor to start it it's a hitec 425bb the plane is a hangar 9 matt chapman cap232 it has done it to the same servo and wing half twice
#90
My Feedback: (84)
WI
I would use all Metal Gear servos in this setup. The carb in your picture shows the plate but I never seen one like that (black in center with 4 screws), but some where on it should be a small hole.
