DA 50 with smoke
Old 05-09-2006 | 09:45 AM
FXD
Default DA 50 with smoke
I have a da 50 with show time smoke pump. I get great smoke at low rpm but at mid and hig throttle get next to none. any one have a fix. thanks fxd
Old 05-09-2006 | 11:10 AM
Tor's Avatar
Tor
Default RE: DA 50 with smoke
Maybe the exhaust pressure becomes too big for the pump to overcome. How many volt are you running on the pump?
Old 05-09-2006 | 11:56 AM
Cobra1's Avatar
My Feedback: (42)
Where are you injecting the smoke oil. It should be as close as possible to the exhaust opening as that will be the lowest pressure area.
Old 05-10-2006 | 08:21 AM
FXD
I am running a slim line smoke muffler. and a 6 volt battery
Old 05-10-2006 | 06:42 PM
WLJ's Avatar
WLJ
My Feedback: (108)
Are you running check valves?
ORIGINAL: FXD
Old 05-12-2006 | 07:36 AM
FXD
Yes i am running a check valve between pump and muffler as per showtime instructions. thanks fxd
Old 05-12-2006 | 03:05 PM
Tor's Avatar
Tor
Is your pump capable of running higher voltage? Maybe 6 volts isn't enough to overcome the backpressure.
