wierdness 3W 75US
My Feedback: (52)
UT
So I bought a used engine and got it running, had it in my airplane for about 5 flights now.... the other day i started her up just like normal, let it idle for a minute, and then just as i was about to take off i noticed my transmitter was falling apart.... So i switched my info over to my friends trans... and after that it never started!! I went back to mine just to try to start it to see if i had the wrong settings.... it still didn't start. i changed the plugs, it didn't start, i went back to factory settings on the needles, it didn't start. I'm not sure what else to do!? I took out the plug and put on the cap, and turned the engine over, and i watched it spark so i know i've got the spark- I know the needles are set right.... i know its getting gas.... what can I do at this point?
My Feedback: (52)
UT
i guess the battery wasn't charged enough.... i charged it up and it fired right up...... i guess i need something w/ more mah cause this one doesn't last long- 6V 1400 you'd think that would be enough,.......
My Feedback: (52)
UT
jr8103- had a lot of bad luck w/it latley- fuel softens it up, and plastic breaks.... sent it in a lot.... i try to keep it dry and protected... but i guess i'm not doing a very good job... i just ordered a hard trans case for it
Man, I have a 9C and I've gotten fuel on it, oil from test running the engine, etc. Still going great. Going back to what you said about the battery, you may need a bigger one. I'm using a Li-ion pack and it seems to really run it down. If it's NiMH, they tend to discharge faster to.
My 8103 has had several crack also. I have had them on the back half around the switches and also close to the LCD. I really enjoy JR radios and the way they fit in my hand, however, I may switch back to Futaba on my next radio....
thanx/Bruce
thanx/Bruce
