Need engine decision advice
Old 12-22-2002 | 04:21 PM
My Feedback: (12)
Default Need engine decision advice
Hello
I am building a cg untimate and I think that I want to put a 120 size 4 stroke in it. I am currently looking at a ys sf 120 and a os 120 older version. Is there much difference in weight? What does the sf stand for in the ys engine?
Thanks for any advice.
Jeff
Old 12-22-2002 | 05:14 PM
My Feedback: (62)
Default Hi Jeff
This is an age old question, but a good one. The YS designations have eluded even the best of them. You should do two things, (1) Do a search on the subject as it's been out there before, and (2) Ask the sf question in the YS forum. I know you'll get what your'e looking for there. As far as which one, it depends on who you ask. After using YS in my competition pattern days, personally I would use nothing else. They are a bit finnicky, but once set up they're flawless in performance and reliability. You need to be a bit of a tinkerer with the carb and fuel delivery system. It's not impossible, but can try your patience at times. They also tend to be a little heavier than most comparable engines of their size, but the performance often outweighs the extra ounces. Just my opinion and Happy Holidays_bob
Old 12-23-2002 | 12:47 PM
My Feedback: (16)
Hi Jeff,
Have you thought of trying an RCS 1.4 gas engine in this airplane. It is a really light engine and will turn the same prop as the 4-stroke with a great savings on fuel costs. Check out the specs at their site.http://www.rcshowcase.com/ Good luck
Old 12-26-2002 | 01:18 AM
My Feedback: (19)
fancman /jjoos99
I AGREE WITH FANCMAN
I HAVE THREE RCS- 1.4 . IF BROKEN IN PROPERLY THE POWER /WEIGHT
IS AWESOME THEY ARE LIGHT VERY POWERFUL AND RELIABLE, NO FLAME-OUTS. 16-8 MASTER AIRSCREW @9000 RPM . FOLLOW THE BREAK-IN, BE PATIENT. PJAMESRC JIM
