Bme 90/u-can-do combo ??
Old 06-05-2006 | 05:57 PM
Default Bme 90/u-can-do combo ??
Was thinking of installing the new bme 90 in a 60 or 40 size ucando,anyone using this engine?how does it run?will it last as long as other gas engines?will it fit in a ucando?Thanks.
Old 06-05-2006 | 11:50 PM
Default RE: Bme 90/u-can-do combo ??
Sent Pm
http://www.rcuniverse.com/market/item.cfm?itemId=198298.
Old 06-06-2006 | 09:37 AM
Although I haven't run the BME 90, I have had U-CAN-DO 60s with 90-91 glow engines installed.
IMO a 90 gas engines will not do the job because of less power than glow and the added weight of the ignition system. The 90 glow engines I had installed on the UCDs were more than adequate and pulled the aircraft with authority. However, the best combination I had was an OS 120 FS. That engine/airplane combination allowed you to do anything you wanted with power to spare. I have been contemplating a U-CAN-DO 60 with an OS 108 as that combination should be very interesting.
I suggest you spend your money on a glow engine.
Regards,
doubledee
Old 06-07-2006 | 03:28 PM
Has anyone tried the ucando 40size with the o.s. 50sx??Will this motor pull the plane adequately??
Old 06-07-2006 | 08:02 PM
Richard L.'s Avatar
My Feedback: (24)
Yes, the OS 50SX will pull the plane adequately. The YS 63 will pull the plane with authority. Likewise, the YS 91/110 will pull the UCD 60 straight up from a hover while weighing 5-6 oz less than other 120 four strokes.
Old 06-07-2006 | 08:10 PM
mrbigg's Avatar
My Feedback: (21)
put it on the .40 size. I'm putting a glow .90 on a sig fun fly now. The BME is next when the cash flow allows.
Old 06-08-2006 | 10:13 AM
I have an U-Can-Do 60 with a Webra 120 speed and APC 17x6 prop. It is just enough power for 3D and in my opinion anything less will be marginal.
I also have a friend with an 40 size U-Can-Do and a Supertigre 90 and it is a very nice combo. I guess the BME 90 will be good in the 40 size but never in the 60 size.
Andres
