50 CC props?
Old 06-05-2006 | 11:52 PM
My Feedback: (8)
Default 50 CC props?
Whats a good starting prop for a 50cc Gasser( Quadra 50 EI)? I have a 20 x 8 Zinger Pro. Is it enough prop?
Turbo
Old 06-06-2006 | 12:12 AM
3DFix's Avatar
My Feedback: (29)
Default RE: 50 CC props?
20 x 8 seems too small. You want your rpm around 6700 - 7000 at full throttle. A good break-in prop for a 50cc is 22 x 8. After break-in go to a 23 x 8. Everyone has their own preference, I like Mejzlik CF
Old 06-06-2006 | 08:33 AM
Richard L.'s Avatar
My Feedback: (24)
When in doubt, use a tach to double check the rpm as stated above. My smaller 39cc gasser already spins a 20x10, so you do not want to use a 20x8 on yours.
Old 06-06-2006 | 02:37 PM
charrua's Avatar
My Feedback: (47)
I used a Menz 22x8 to break in mine and then a NX 23x8,,, also has a 22x10 BME it looks really cool but it's too big for it!!!!
Old 06-06-2006 | 02:46 PM
My Feedback: (8)
Thanks for the info. I'll start with a 22 x 8 or a 20 x 10.
Regards,
turbo
Old 06-07-2006 | 07:30 AM
Zeeb's Avatar
My Feedback: (41)
ORIGINAL: turbo.gst
Regards,
turbo
They are not exactly common, but there are some 21x8 props made. Since we lose some power at our 4500 ft. elevation I started with a BME 21x8 on my ZDZ-50 for break in, then to a 22x8 Mejzlik which seems to work really well. I also tried the 22x8 Bambula but it was too much load on the engine.
Which brings up the other thing about prop selection, there are quite a few different profiles out there producing different RPM numbers in the same size when switching between brands. So it really is a trial and error deal that can depend on specific airframe/engine combos and what kind of flying you like to do, which can be kinda spendy...
