ZDZ 40 question
Could one of you guys that own a ZDZ 40 or 40b do me a big favor and measure the distance from the mount holes to the top of the carb fittings/linkage. I will have the engine mounted inverted and need to know if I will have enough clearance so nothing sticks out of the top of the cowl. I have 1 inch from the mount hole center to the top of my cowl. Can the carb be rotated 180 degrees?
My Feedback: (198)
The carb can NOT be rotated because of the source of the crankcase pulse hole in the adapter. Sorry....
I don't have one to measure, but I put a ZDZ 40 in the H9 25% Cap (the old Matt CHapman), and the adjustments DID NOT clear (with a BIng) if you have the Walbro, they will clear, as the Bing needles are quite a bit taller (who knows why?)...sorry I can't be of more help.
No such thing as a carb that can't be rotated..All you need is a different block and a pulse source..Every G62 I ever made is rotated..I put a 6-32 setscrew in the original pulse hole in the cylinder so it won't leak, then put a pressure fitting in the crankcase and a Walbro #128-218 90 degree fitting in the carb rear cover to connect the crankcase fitting to the carb with a seamless molded neoprene fuel line ..Works better than the original hole, which can leak if the carb is loose....
Some chainsaws are made this way from the factory, with a fitting in the case and another in the carb..No big deal....
My Feedback: (198)
rcign - Carbs can be rotated - BUT - as you said, NOT without additional pressure tap points, or Different adapter bases. I made an assumption that he wants to use the motor stock, without modifications.
