BME 110 mounting dimensions
Old 07-19-2006 | 07:45 PM
AHPowelson's Avatar
My Feedback: (37)
Default BME 110 mounting dimensions
Can someone provide me with the BME 110's mounting dimension? The engine is on its way and is being mounted in a H9 33% Cap.
Old 07-19-2006 | 08:56 PM
My Feedback: (7)
Default RE: BME 110 mounting dimensions
here you go ...
Old 07-19-2006 | 09:34 PM
AHPowelson's Avatar
My Feedback: (37)
Perfect! Can you confirm that the distance from the backplate to the front of the hub is 6 inches (15.24cm)?
Thanks!
Old 07-19-2006 | 09:41 PM
My Feedback: (7)
Sure
That's what I got: ( BTW , no more prop slippage with BME 110 engines !!! ) :
Old 07-19-2006 | 10:28 PM
AHPowelson's Avatar
My Feedback: (37)
Thanks so much for the help!
Old 07-19-2006 | 11:18 PM
My Feedback: (7)
Welcome !
Old 07-20-2006 | 08:35 AM
bodywerks's Avatar
I got 3.041" if you don't want to use centimeters. However, I do believe he has changed the backplate on newer designs - it is no longer a radial mount. That's not to say yours isn't, but I'd contact whoever you are buying it from and ask if it is a radial mount or not.
Old 07-20-2006 | 09:05 AM
My Feedback: (7)
I think is a good point ,I hope AHPowelson reads this before drilling its firewall !!!
Please confirm so that we all BME engine owners know about that fact.
Old 07-20-2006 | 11:13 AM
AHPowelson's Avatar
My Feedback: (37)
Thanks all. It's a used engine with the radial mount and the older hub. BTW, Cheif Aircraft told me the 110 has been discontinued and is being replaced by the 115. [:-]
