g 62 on ch ingnition problems
Old 08-09-2006 | 08:48 PM
Default g 62 on ch ingnition problems
I bought a used g62 at a swap meet that has been converted to ch ingnition with a mechanical advance, the problem is that the sleve
that attatches to the mtr has come loose and moves fwd causing damange to the next sleve that rides over it. they now bind,so when the mtr runs at full throttle it starts to surge and then backfires and quits, my question is there replacement parts or a kit that can be purchased to fix this mtr, or is there someone that is good with these engine that you would recomend , thanks, goose
Old 08-09-2006 | 08:53 PM
Default RE: g 62 on ch ingnition problems
Contact Terry at CH Electronics. They have all the parts to take care of it or you can send it to them for repair. They're generally pretty low on maintennance levels but the set screws need to be checked every once in a blue moon or so,
Old 08-09-2006 | 10:23 PM
www.ch-ignitions.com/
