Need Help Bax
Old 08-10-2006 | 02:25 PM
CarverTripp's Avatar
Default Need Help Bax
Hello,
Could you please tell me what model and or part number is my Walbro carb? The engine is the Fuji 50EI. I'm still trying to locate a choke spring and ball, goes in behind the choke shaft to keep it open or closed.
By the way, got the engine running, thanks for the tip, it was the fuel, not enough.
Carver
Old 08-11-2006 | 09:37 AM
Bax
Default RE: Need Help Bax
The model of the carburetor is cast onto the body. On the BT-50EI, the carb is a model #HDA 133B.
Old 08-11-2006 | 01:35 PM
Bax, Thank you for the information
