Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Webra Bully gas replacement engine? >
Old 08-22-2006 | 03:53 PM
Paul Grubich's Avatar
Default Webra Bully gas replacement engine?
I am replacing the old Webra Bully with a gas engine but not sure of what size or brand to get. The Bully swings a 20x6 prop ao need something in that range, 18 to 20.
The main problem is the Bully is a short, light engine and some of the gasers are longer and heavier.
Advice needed guys.
Paul
Old 08-22-2006 | 04:34 PM
My Feedback: (18)
Default RE: Webra Bully gas replacement engine?
What is the displacement of the Bully? I think it's 35cc, but since I haven't used one I don't exactly know... I have a friend who loves these engines and has stockpiled a few...
Old 08-22-2006 | 05:57 PM
My Feedback: (29)
Paul,
The Bully is based on a Sachs saw parts. If yours has a needle bearing rod, Scott at Brielli engines will convert it to gas at a reasonable cost. RC Ignitions may also. A Brison 2.4 is a forty cc based on Sachs and is about the size of a Bully for around $400.
Dave
Old 08-22-2006 | 08:29 PM
my MVVS 35cc gasser may weigh more but it is one power house, it will swing a Zinger 20x8 pro to 7690 peaked (7500 tuned for flight),,, it will swing a 3W 20x8 at 6800 (tuned 6600 for flight), the 3W prop pull's much much better and produces much more top speed too..
Jim
