3w41 back carb
I have a 3w 41 and Im putting in on a cap 232. I have not worked with a eng with the carb on the back of the eng before. I will have to put a hole in the fire wall to make the eng fit. What I would like to know is, With the carb in the plane like it will be, is there somthing I need to do. What kind of probs will I have? Will he eng get air? Will I have to put a hole in the plane? Can I run a tub from the carb to the out side of the plane? If you all can help. plz do.
Paul
Paul
Also I read somewhere that installing a stack (trumpet) to the carb will eliminate the spray. I put one on my ZDZ 40 and it still sprays so save your money and pass on the trumpet.
My Feedback: (40)
Well you can buy an airfilter type fitting for the zdz's (maybe 3w as well).
It looks like the old style airfilter for a car and has a enclosed ring of filter around the outside that soaks up the fuel.
I ran a 3w50 and didn't have that much of a problem with it getting wet inside the fuse. Just make sure it's fuel proofed to prevent any long term damage from getting wet.
