Smoke with DA50
Does anyone in here have positive results with smokesystem including the DA50 ?
My setup is DA50, MTW canister and MTW header with smokeconnection.
Is it possible to make good smoke on this setup ?
/Anders
/Anders
I have the version with the tap in the header.
Do you have any experience with smoke on this setup ?
Will it smoke as well as on bigger engines, or only on full power ?
/Anders
/Anders
Smoke production is determined by two things, fluid amounts and heat. If both are in the correct proportions, the size of the gas engine is the smallest part of the equation. Large gassers running twin exhausts usually produce more smoke than a small gasser using a single exhaust outlet. Your DA and exhaust installation should do well.
With a chance of this question starting a religious fight
..... I know there is a lot of solutions BUT :
Which fluid do you guys use ??
I have tried som glycol based fluid which is used on discotecs - no smoke at all :-(
/Anders
..... I know there is a lot of solutions BUT :Which fluid do you guys use ??
/Anders
