Evolution 58gx2 won't start
Old 09-12-2006 | 08:16 PM
  #51
Panzlflyer's Avatar
My Feedback: (15)
Default RE: Evolution 58gx2 won't start
Try this..choke on and just 2 or 3 flips and then choke off flip till it starts. I dont know why but thats what it took to get mine going. Never did that before it went in.
Old 09-13-2006 | 01:39 PM
  #52
greyhound man's Avatar
I'll try that, but it is not starting right now as is getting spark, gas running out of the carb and exhaust, still not even a pop.
Old 09-13-2006 | 01:49 PM
  #53
nope still won't start, tried choke on for 3 flips and stopped counting after 25 flips. even pulled the spark plug first to re-verify spark and that it was not flooded.
EDIT: I did finally get it to start, it seems to like to start at a higher throttle setting about 1/4 throttle or a little less, and easily restarted while still warm.
Old 09-13-2006 | 09:02 PM
  #54
bluemagic98's Avatar
i do trim mine up a little when i flip it but its been consistant at starting cold Hot however I need to flip it more chole off i seem to get in trouble when i flip it with choke on. if this dont pop after the 3rd or 4th flip chole on i kill the choke kill the ignition and open the throttle wide open no choke and flip it 4 times then i turn tthe ignition on and reduce the throttle to just off idle and flip it it ussually fires right off after that. the other thing i noticed is after it pops and i open the choke and flip it it takes 2 or 3 theen it pops again and 2 more flips before it runs but like you said i think it needs a tad more throttle to start faster ill be trying that tomorrow
Old 09-14-2006 | 06:22 PM
  #55
Tried to go fly today with pretty dismal results. Took forever to get it started and 30 seconds in to my only flight it dead sticked, then It was unfriendly about starting again, my local engine expert believe's that the pop off pressure is too high, after playing with it for way too long, we gave up and will tear it down later.
Old 12-10-2006 | 05:30 PM
  #56
i have a new 58 no spark right out of the box sent ingetion back to horizon thay sent a new one. started engine can only get 1/4 throtel and engine stalls
Old 12-11-2006 | 06:20 PM
  #57
bonedaddy41's Avatar
tee681,
Right out of the box, the needles are too lean. Try richening both a bit.
Old 12-11-2006 | 07:14 PM
  #58
After sending my engine back and fourth to horizon for several months, I gave up on their service and sold the second replacement engine they sent me. and yes they replaced my engine twice.
Old 12-11-2006 | 08:57 PM
  #59
rmh's Avatar
rmh
what engine(s) do you have which you found to be easy to handle?
Old 12-11-2006 | 11:14 PM
  #60
ORIGINAL: dick Hanson
I have a ZDZ 50ng and DA 50 which are both great, easy to start, tune, and run great. My 58 ran great, and had no problems with it what so ever until it ate the piston ring after 5 gallons of fuel.....still running 32:1 break-in. If horizon had not sent me a non functioning engine 3 times, I might still own an Evolution......I am not dissatisfied with the engine, merely the quality of service.
Old 12-12-2006 | 12:11 AM
  #61
rmh's Avatar
rmh
Thanks - I appreciate the candid answer.
