Nagging G62 Problem
Old 10-21-2006 | 03:15 PM
My Feedback: (25)
Default Nagging G62 Problem
I have a G62 mounted inverted in a Pitts. This engine could be 10-15 years old and is equipped with a Jump Start unit. Have no idea ho many hours on it, but most of the time it runs just fine. starts OK, idles OK, transitions ok, good top.
Heres my problem - it cuts out when inverted or put into verticle angles of bank. Straight and level just fine. I have gone through the entire fuel system. Everything appears fine, the clunk is free and flopping.
Does anyone have any idea what may be causing this. The plane is a rare and beautiful 1/3 Pitts. I don't want to loose it due to a deadstick. Already had one.
One last fact. I've only had this plane for a short time and only flown it six or seven times. so I got no history with it.
Old 10-21-2006 | 03:40 PM
Default RE: Nagging G62 Problem
I would redue the entire fuel line set-up. Take Care....Capt,n
Old 10-21-2006 | 09:36 PM
Nogyro's Avatar
My Feedback: (10)
If it's that old and you're sure the tank and lines are ok, the first thing I would do is take the carb apart and put new diaphragms and needle in it. Also replace the fine screen filter that's in there while you're at it. It all comes in a carb kit from the local saw shop.....$10 max.....
Old 10-21-2006 | 11:00 PM
I agree with Nogyro, Get the carb kit. It's a simple fix. I had one that was on the shelf a couple of years and it again ran like brand new.
Old 10-21-2006 | 11:20 PM
My Feedback: (25)
Saw shop? This is the desert man Just kidding. So if I don't have a local saw shop around here, what might be another source. thanks for the info.
Old 10-22-2006 | 01:13 AM
Rcpilot's Avatar
My Feedback: (78)
http://www.horizonhobby.com/Products...ProdID=ZEN6272
It's out of stock, but if your having that much trouble finding a carb kit--this looks like your best bet.
Don't you have a small engine shop anywhere? Nobody uses weed eaters around there? No one uses back pack blowers? No grass to cut? You got absolutely NO small engine shops around?
Old 10-22-2006 | 01:14 AM
tkg
Do you have the pressure refference vent piped into the fuse so that the airflow in the cowl doesn't screw up the fuel mix??
Old 10-22-2006 | 01:29 AM
Splais,
I know you're in the SW corner of the state, but RCIGN can't be more than a phone call away. It shouldn't take more than a couple of days for the mail to make the trip.
Old 10-22-2006 | 02:32 AM
Antique's Avatar
$5 for a kit, if mailed Monday you would get it Tuesday...Send address....[8D]
Old 10-22-2006 | 07:03 PM
Nogyro's Avatar
My Feedback: (10)
ORIGINAL: splais
oooops, didn't notice where you lived. Ralph will fix you up. If not, maybe ya'll have leaf blowers or weed whacker shops out there.
Old 10-22-2006 | 07:36 PM
Rcpilot's Avatar
My Feedback: (78)
Maybe someone has reversed the operation of a leaf blower to handle the local pest population.
You guys got gas powered snake suckers down there? Surely there must be a snake sucker repair shop in the vacinity? [sm=tongue_smile.gif]
