ZDZ-50 Problem! Please chime in if u can help!!
I own a ZDZ-50 in my 29% Katana. I have put like 5 flights on her and then after the last flight, the ZDZ decided to NOT RUN. Actually it starts up then in about 2 seconds, it stops running. It sounds like its starving for fuel then it just dies. I have spent the past 2 days frustrated and not being able to figure out the issue. I have opend up the carb and completely cleaned it out, changed the fuel lines, checked the tank, new plug, peaked the Ignition batt. The whole nine yards, bit the same problem remains. Like I said, I was flying and it was just fine. This problem literally popped up when I went to start it again for a next flight. Now it wont even run. It starts and dies. If any of you here can chime in if you even remotely have an idea I would GREATLY appreciate it. I am frustrated and after 2 days of flippin that 23-8 prop, I'm exausted. Thanks guys !
