DA 150-3W140 measurements
I need to know the difference in the length from mounting plate to prop hub on these two engines. Want to go from the 3W 140 to a DA 150 and wonder if I add to the engine box length or cut some off to make this possible. Can't find the DA dimension. Thanks.
My Feedback: (69)
AR
RE: DA 150-3W140 measurements
According to AI, The 140 is 195mm and the DA is 195 according to below
http://www.toni-clark.com/ftp/da150_3v.pdf
My Feedback: (50)
CA
A 3W140TOC98 is about 5mm shorter than a DA150. Please don't hold me to that, but I was switching those engines back and forth on a 37% Yak, and I needed to shim the 3W slightly.
DKjens
DKjens
