ZDZ 160 Carb????
My Feedback: (33)
CA
ZDZ 160 Carb????
What carb is on the older 160. I just got one from someone with a Walbro wb27. It runs off of crank pressure tap from a hose to the top of the crank instead thwe one through the phenolic block. In the carb was a set screw to block the traditional method. Any advice would be welcome. With the cureent system it runs way to lean and won't spool over 4700 and runs hot. So obviously this can not be right. HELP?????
RE: ZDZ 160 Carb????
If the pressure tap was not supplying pressure -the engine would not run-period
someone has been " working" on this engine -and I suggest you go directly to RCShowcase -with serial number and se what changes -if any are available
