Zenoah Help
Old 10-28-2006 | 11:23 AM
Default Zenoah Help
I need some instruction on changing the Plug Cap and Spring on a Zenoah Engine.
Thanks.....Dave
Old 10-29-2006 | 09:49 AM
Antique's Avatar
Default RE: Zenoah Help
Need a better explanition,, don't understand the question ???
Old 10-29-2006 | 02:07 PM
I have the old spring and boot off and have new pieces to install. When I took it off I couldn't see how the wire was attached to the spring.
Thanks.....Dave
Old 10-31-2006 | 07:19 PM
Come on Guys, HELP!!
Thanks.....Dave
Old 10-31-2006 | 07:55 PM
Rcpilot's Avatar
My Feedback: (78)
Screw the boot onto the wire. Done.
Not that hard.
Old 10-31-2006 | 08:28 PM
Antique's Avatar
There are two pieces, the spring and the boot...The spring is a small coil with 1/2 inch long straight part sticking out...there is a 90 degree bend on the part that sticks out...The bent part is sharp on the end...You will see a small hole in the wire where the old piece was stuck in the wire...Stick the end in the hole...Put some WD40 in the boot...Push the boot on the wire...
Old 11-03-2006 | 08:35 AM
RCIGN1.....THANK YOU
I FIXED IT IN ABOUT 30 SECONDS FOLLOWING YOUR INSTRUCTIONS.
THANKS AGAIN.....DAVE
