Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Webra 1.20 and Dave Patrick Ultimate >
Old 01-19-2003 | 09:18 PM
Default Webra 1.20 and Dave Patrick Ultimate
I am putting a Webra 1.20 glow engine in a Dave Patrick Ultimate ARF, his 1.20 size bird.
Does anyone have suggestions on what prop to use and what size fuel tank for a 10 to 12 minute run?
Jerry
Old 01-20-2003 | 10:32 AM
Jerry,
I have a Webra 120 in a scratch built Ultimate ( similar in size to yours ).It is a very reliable powerful engine.I use a 20 oz tank & currently a 16.5 x 8 Bolly carbon prop.I previuosly used a 15x8 APC ( a good prop as well ) although the 16.5 x 8 seems a better choice performance wise for my airframe.Hope this helps.
Old 01-20-2003 | 04:52 PM
flyinrazrback's Avatar
My Feedback: (69)
Apc 16x8 worked awesome on mine, had it in a goldberg ultimate.
Old 01-21-2003 | 09:39 PM
WHAT WAS YOUR FLY WEIGHT WHEN ALL WAS SAID AND DONE ON YOU ULTIMATE? DID THE 120 HAVE ENOUGH POWER TO HOVER? I RECENTLY PURCHASED A 120 ARF ULTIMAE BY DAVE PATRICK, AND WAS PONDERING WHAT I AM GOING TO USE FOR POWERPLANT.
R/
Old 01-23-2003 | 02:00 PM
Default DP Ultimate
I have a DP Ultimate and and originally had a YS 120 on it with a APC 16-8 prop and it was awsome in all areas but one.It would just hover (hang on the prop ) with not much pull out.I swapped to a Saito 180 with a APC 18-6 and hang on to your Transmitter! It had unlimitted vertical and honestly I could not tell any difference in flying because of the heavier motor.That plane is great.It won the Biplane shootout in MAN a few months ago.Nowto the big drawback to the Saito 180.Ihad to put an additional tank which brought it up to a 24 oz. cap. to get a comfortable 10 min. flight.That Saito loves fuel!The inverted flatspin is very flat and descends slowly and looks great. Dave
Old 01-26-2003 | 02:02 AM
RCFLYER DAVE,
THANKS FOR THE INFO I AM GOING TO GO WITH A SAITO 150 I THINK.
Old 01-26-2003 | 02:12 AM
You'll like the 180 better for brute power.
Old 01-26-2003 | 06:29 AM
My Feedback: (31)
rcflyerdave
what kind of numbers does your Satio 180 turn the 18 x 6 APC?
Old 02-03-2003 | 03:48 PM
THOMAS WILLIAMS,
THERE IS NOT MUCH GAIN OVER THE 1.50 IN USING THE 1.80. I THINK IT IS ONLY SOMETHING LIKE 7% INCREASE WITH A LITTLE MORE WEIGHT ON THE 1.80. I REALLY THINK THAT THE 150 IS GOING TO BE THE BETTER WAY TO GO, BUT I AM NOT COMPLETLY SURE YET.
ANY WAY THIS IS MY .2 CENTS WORTH.
R/
