Throw some light
Old 11-10-2006 | 11:33 PM
Default Throw some light
Im in process of installing a DA100 in a WM 33% ultimate . it requires the cowl to be cut for the motor to fit , this makes the carb stick out of the cowl at the underside and will be exposed to the airstream, am i going to face probs with this setup i.e motor running lean rich etc. any 33% ultimate owners can shed some exp on this matter , or anyone with similar setups can share their experiences. Thanks folks .
Old 11-11-2006 | 05:18 AM
Default RE: Throw some light
Carb plate might be just the thing for you.
Ahmed
Old 11-11-2006 | 05:01 PM
RTK's Avatar
RTK
As previously stated, a carb plate might be the ticket.
I would first fly it the way it is, then if you are experiencing problems experiment until you have them corrected.
Remember, if it ain't broken don't fix it.
