Need help with High Speed
Old 01-26-2003 | 01:12 AM
14th_Reaper's Avatar
My Feedback: (-1)
Default Need help with High Speed
Guys I need some help with a problem concerning an MDS 2.18.
The engine will idle beautifully and will accept throttle input up to about 1/3 or so. If you gun it, it will take it until just past the 1/3 mark then it really starts to bog down.
I pulled fuel lines off, checked for debris, checked the fuel filter, it was clean,checked for kinked lines, there are none, checked for different sized fuel lines, they all match, checked the carb for any blockage, again - none. I am now lost on what to do next. The engine ran fine on a WM mustang I had and moved ot over to the PW Extra 300s. The glow plug is new, only been used 2 days now. She idles like a champ but wont take fuel. I am running 5% through it like the manufacturer suggests... I need help!!!!!Please!
