Can someone identify this engine ?
It's probably a Quadra, but I'm not sure exactly which type it is. I want to sell it, so I would like to know some more about this engine.
Much appreciated,
Hans
Much appreciated,
Hans
Pull the muffler. Using a wooden probe like a toothpick or skewer, measure the cylinder bore. If its 40mm(1.57") the engine is a 41/42. If it's 37mm (1.44")it's a 35. The stroke will be the same so measuring that is of no use. Tex.
