Evolution 26X10 Propeller
IN
I'm not sure if this is the correct place to post this, but I figured I would try anyway. I've got a ZDZ 80rv that I'm finally getting around to putting into an airframe. I'm going to use a Evolution 26X10 for the first couple of flights before I more into a carbon fiber prop. My question is this. I need to have my spinner custom cut for this prop, but I want to have some room to go to another brand. Does anyone know who makes the prop or its dimensions, or if carbon props are typically larger than wood so it won't be a problem?
Any advice would be greatly appreciated.
My Feedback: (69)
AR
Are you wanting to get a Tru turn spinner? If so if you get the menz/mejzlik cut they usually fit up to a 28x10 prop, so that should work. FYI Don's Hobby Shop usually has the best price on TT Spinners if you have not bought it yet.
