Zenoah G-23 Manual
Zenoah G-23 Manual
Does anybody know an electronic resource for a Zenoah G-23 manual? Or even a printed version? As far as I can tell Horizon Hobby no longer offers this manual since the engine was discontinued.
I bought a used G-23, and it's missing a few parts, some obvious (prop nut), some not. I need part numbers and information specific to that motor. I'm assuming the operation is similar to the G26. I have that manual, but it doesn't offer any specific info about the G-23.
Any info would be greatly appreciated.
Thank you,
MI
Thank you,
MI
DC
RE: Zenoah G-23 Manual
Same crank, hub,stud, nut, magneto parts, carb insulator block, same bearings...
Larger carb, different spark plug..
Case dimensions are the same but the G26 case ports match the larger ports in the cylinder...
