G20 #s waassup?
WY
G20 #s waassup?
It got above freezing today so broke out the Laser 200 with the G20 in it to get it ready for spring.
Its only turning 8900 on a 16x8 APC and 9100 on a 17x6 APC.
Must be the altitude 5400 ft[]
RE: G20 #s waassup?
whats wrong with you.????? Not happy with those nos? 8900 16x8 and 9100 17x6... Heck that is a lot more than those touted 26cc from china. You prolly can spin 17x8 at low/mid 8000.
My Feedback: (23)
RE: G20 #s waassup?
Just because your prop is turning at a high RPM, it doesn't mean it's really doing anything productive.
I just plugged in your RPM numbers into ThrustHP and got the following:
15-8 @ 9650 14.14 lbs of thrust 73 MPH
16-8 @ 8900 15.57 lbs of thrust 67 MPH
16-6 @ 9100 20.75 lbs of thrust 51 MPH
Higher speed, lower thrust, takes longer to get to speed.
I'd say your numbers looked right on the money.
RE: G20 #s waassup?
I think you figures are a bit of wishful thinking. Using Pe thrust chart which has been proven to give fairly accurate figures, and inputting TKG's altitude of 5400 ft. and your prop / rpm data based on a APC props, IMHO provides a more realistic set of numbers.
15x8 @ 9600 11.58 lbs. of thrust 63.5 mph
16x8 @ 8900 12.26 lbs. of thrust 58.6 mph
16x6 @ 9100 10.78 lbs. of thrust 44.9 mph.
Karol
Karol
My Feedback: (23)
RE: G20 #s waassup?
I was just showing him that the numbers he got were pretty good for that engine.
To do a more accurate test, you have to try a lot of props and do a lot of flying.
Thrust and speed simulators, no matter who wrote them, are pretty good for showing differences between props, RPM, etc.
But that's about all....
WY
RE: G20 #s waassup?
I fly the plane on the 17x6 @9100... The other props are the left overs from the find the right prop for the plane game...
I don't quite know the reason for the large diff between the 16x8 and the 17x6 should be closer in RPM, but I rechecked and the 17 is about 300 rpm faster.
And WAASSUp is dis
And WAASSUp is dis
WY
RE: G20 #s waassup?
I ended up with the 17x6. It gave a more constant speed upline vs down line.
If it was in the 80's and everybody was flying "rocket ship" pattern then the 16x8 and pipe would have been the ticket
