Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Need Help With Moki Needle Settings >
Old 02-15-2003 | 07:41 PM
rab
My Feedback: (10)
Default Need Help With Moki Needle Settings
I bought a used moki 2.10 and did not get a manual. Can someone please tell me what I need to set the needles at. What is the little dial with the +- on the side of the carb for? Thank you very much.
Old 02-15-2003 | 09:01 PM
Flyfalcons's Avatar
The little diad is the low end adjustment cap. If you pop it off you will see a small hole where the fuel goes through. You'll also see that it is very sensitive to adjustments. For starters, set the low end cap so the mark on the inside and outside are lined up. Turn it clockwise (toward the '-') to decrease the fuel and lean the low end mixture. I have a pump on my Moki so my high end is about 1-1/2 turns out. If you don't have a pump, try 3 turns out to start with. Even if the engine is sloppy rich it should still run. Remember to get the carb really wet to get the engine started.
