GP Kill Switch wiring?
My Feedback: (71)
Anyone with experience installing this kill switch? The wiring is not typical of a switch. Not clear on where to plug the switch wiring to the ignition module. I'm installing it in a BCMA SPE40 gasser.
Link for the switch:http://www2.towerhobbies.com/cgi-bin...&I=LXJ776&P=ML
Link for the ignition module:http://www.bcmaengines.com/BCMA26.htm
CA
The switch is a bit confusing at first. I wire mine to make a constant loop.ie through the battery to the micro switch to the ignition to the on off switch and back to the battery. Only use 2 wires from the switch find the in- out or 1 red 1 black remove the rest. solder in a male to connect in the battery and a female to connect in the ignition. Add if you need to, a charge lead for the battery. Use a good silver solder. I use servo extension wires and ends and cut everything to fit each application.
