Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Evolution 35GT, pro's,Con's,Good,Bad >
Old 05-16-2007 | 09:03 AM
My Feedback: (65)
Default Evolution 35GT, pro's,Con's,Good,Bad
I need a Gas engine in the 35cc range and have been looking at the Evolution 35Gt and was wondering if anyone had any feedback, GOO or Bad.
Ron
Old 05-16-2007 | 10:36 AM
P-51B's Avatar
Default RE: Evolution 35GT, pro's,Con's,Good,Bad
Search under MVVS 35 or 35 IFS and you should find a thread. It is the same engine. As far as I have heard, nothing but positive feedback.
Old 05-16-2007 | 10:55 AM
Jake Ruddy's Avatar
My Feedback: (40)
Just make sure you put it on a pipe.... standard mufflers it's not the most powerful engine out there.
Old 05-23-2007 | 01:24 AM
Does anyone have a weight for this engine with ignition and everything? Thanks!
Old 05-24-2007 | 12:24 AM
well it may not be as powerful as some 40cc engines, but I have a MVVS 35 with a inverted side muffler in my 15&1/2 pound 82 inch span GeeBee Y and it pulls it very well,,
my MVVS 35 with that inverted side muffler will spin a Zinger 20x8 Pro at 7500 "tuned for flight" and a wood 3W 20x8 at 6800 "tuned for flight",, although I think I need to spin it a bit higher than 6800 so I am going to order a 3W 19x8,,
my engine is 3 summers old now and I have not kept up on the MVVS electronic ignition, but if you get the same ignition I have you will need a 5 cell pack, just not enough spark on a 4 cell to start it well, but you better ask about that before buying, other than that I have had NO problems and I love the motor,, once primed and popped mine will start in 2, 3, or 4 flips..
Jim
Old 05-26-2007 | 01:08 AM
The 45cc is lighter then the 35cc. Seems like a no brainer, more power less weight. All the Evolution/MVVS motor run very well.
