Evolution 35GT
Old 06-25-2007 | 10:32 PM
My Feedback: (15)
Default Evolution 35GT
Anyone have any real world numbers on the 35. No speculation or flaming please just facts. How does urs run?? thanks
Old 06-26-2007 | 02:37 AM
Default RE: Evolution 35GT
I have the MVVS 35, peak RPM with a 3W 20x8 is 7370,, at over 15 pounds it doesn't pull my PA (ARF) GeeBee Y off the ground as it would a light 3D plane, but I have to say this little motor sure pulls..
Jim
Old 06-26-2007 | 07:11 AM
I used to fly MVVS 35 (same as evolution) with EDGE 540T wingspan 73" from Wildhare. The engine is really good but it is a bit heavy. When I installed it to 73" EDGE, I can perform all aerobatics well but have a problem with authority for HOVERING.
The power is too fit for it.
Engine is easy to start and reliable and never give me a problem.
Old 06-26-2007 | 07:12 AM
Using MENZ prop 20 x 8 I can get max speed at 7300 RPM.
Old 06-26-2007 | 07:16 AM
Due to heavy weight of engine MVVS35 I do need to relocate two pack 6 volts 1500 mAh battery at the back of rudder servo.
Old 06-26-2007 | 10:49 AM
Antique's Avatar
I just put ignition on a MVVS35..weighs almost 4 lbs, runs well otherwise....
Old 06-26-2007 | 11:57 AM
See [link=http://www.prme.nl/forum/viewtopic.php?t=54]my report[/link] on my forum for complete MTW TD75 tests
This engine hauls much like a 40+cc
35cc
Data sequence: prop; muffler;rpm; header Lcm; header IDmm; remarks
mejzlik 18x10;3271 ;7200; - ; - ;original MVVS 3271 side muffler
mejzlik 18x10;3W-2;7600;20;22; original mvvs header with 3W muffler
3W 18x12 mod;3W-2;7200;20;22; Foil and blade shape modified
3W 18x12 mod;TD75K;7600;20;22; Foil and blade shape modified
3W 18x12 mod;TD75K;7050;30;25; CHT 156°C
3W 18x12 mod;TD75 ;6750;30;25; TD 75 has longer internal header
3W 18x12 mod;TD75;7250;25;25; header still too long for TD75
3W 18x12 mod;TD75K;7420;25;25; CHT 160°C
3W 18x12 mod;TD75K;7650;20;25; CHT 170°C more power than 22mm header
3W 18x12 mod;TD75;7550;20;25; Header still slightly too long for TD75
Menz-S 20x8;TD75;7050;20;25; Excellent pull
Mejzlik 20x8;TD75;7470;20;25; Excellent pull
Mejzlik 18x10;TD75;7830;20;25; The shorter header is a little noisier
Old 06-26-2007 | 12:56 PM
My Feedback: (15)
Considering the 35 for a Giant UCando at 13 lbs. I had an Evolution 26 on it and it would hover but not much left to pullout. JUst curious if the 35 is goin to b much better. Gotta love the way they run. Maybe i am different but i have a brand new DA50 that i was goin to put on it but i cant stand the way it runs, so its for sale. An engine that costs $600 but wont run without burbling the whole way lol. My 26 sings without ever missing a beat. FUnny looking cause the carb is almost as big as the head lol..
Old 06-26-2007 | 03:29 PM
13 lbs is too much to Hover on any 1.60 gas engine. If you get rid of 2 lbs, the 26cc (1.60) will do fine.
Cooling in 3D flight takes very special attention though. A gasser is not like a glow engine.
Old 06-26-2007 | 03:36 PM
My Feedback: (15)
I put the 26 on my Hangar 9 Twist 150 at 10lbs and it does very well. I wanted to know would the 35 pull the Giant Ucando at 13lbs?? What could i expect as far as performance and what prop would b appropriate?? thanks
Old 06-26-2007 | 04:39 PM
yes, and you can use a 20x6 to 20x8 prop
Old 06-26-2007 | 04:44 PM
My Feedback: (15)
Gonna try my Da 50 on it first till i get the 35. This oughta b interesting lol
Old 07-01-2007 | 09:15 PM
BankYank's Avatar
My Feedback: (63)
My MVVS 35GT using a 20X8 Xaor turns 6,600k with about 3/4 gallon through it.(40:1 amsoil regular gas). Using the Inverted pitts wrap around muffler.
Pat
Old 07-01-2007 | 10:03 PM
flyinrazrback's Avatar
My Feedback: (69)
What would be a good prop for this motor for just speed?
Old 07-02-2007 | 02:57 AM
""What would be a good prop for this motor for just speed? ""
well, as I said I'm using a 3W 20x8,, and at over 15 pounds my plane moves along at a pretty good clip, so probably an 18x10, 18x11 or a 17x12, 17x13,,
now, if you went with a carbon prop you may gain a few hundred RPMs, even more..
Jim
Old 07-02-2007 | 07:31 AM
use the right oil (synthetich 2 stroke racing), AND premium gas only. The manual is quite clear about this.
Old 07-02-2007 | 10:02 AM
rmh's Avatar
rmh
ORIGINAL: flyinrazrback
How long is a piece of string?
