High End Tuning Question
Old 07-27-2007 | 09:12 PM
My Feedback: (17)
Default High End Tuning Question
There are frequent references to tuning the high speed needle for max rpm, then richening it for a 200rpm drop. Can some one explain the reason/theory for doing this? Can you really tell any difference when flying the plane?
Old 07-27-2007 | 09:35 PM
AirWizard's Avatar
Default RE: High End Tuning Question
I think the reason you back it off is that in the air the engine will go leaner.
Old 07-27-2007 | 09:43 PM
bubbagates's Avatar
My Feedback: (32)
AirWizard hit it right on the head. plus in most cases you are on the high needle most of the time so you get the added benefit of a little extra cooling from the fuel/oil mix
Old 07-27-2007 | 11:28 PM
rmh's Avatar
rmh
ORIGINAL: AirWizard
Really?
why?
Old 07-28-2007 | 12:20 AM
This is going to get interesting. It's going to be so much fun I'm going to be content to simply watch. Gotta go make some popcorn[8D]
Old 07-28-2007 | 12:52 AM
JoeAirPort's Avatar
My Feedback: (41)
Fuji engines rule.
Old 07-28-2007 | 07:15 AM
My Feedback: (48)
ORIGINAL: dick Hanson
ORIGINAL: AirWizard
Really?
why?
Ya, Me Too!---Why?---
Old 07-28-2007 | 07:37 AM
mrbigg's Avatar
My Feedback: (21)
ORIGINAL: JoeAirPort
Fuji engines rule.
Right On, Jackson![sm=lol.gif]
I think people do it for some kind of half-butt "rev limiter."
Old 07-28-2007 | 07:59 AM
AirWizard's Avatar
ORIGINAL: AirWizard
Really?
why?
Your the engine master.....does it go leaner in the air?
Old 07-28-2007 | 11:45 AM
No, but that's all I'm gonna say
Old 07-28-2007 | 02:02 PM
glover1482's Avatar
I just love constructive posts... RCU rocks!
Fly safe, Glover
Old 07-28-2007 | 03:23 PM
This is just not fair. Someone please come to the rescue and clear up this mystery. Who me, no way
Karol
Old 07-28-2007 | 04:04 PM
In that case, I'll pose a question or three.
If you have adjusted metering needles on the ground to obtain a specific mixture, what action could change those settings when the prop is spinning in flight? Could those specific metering settings change at all? What does or can change between the prop spinning on the ground and spinning in flight? The "does" and "can" are important and often related to performance. In the specific case presented by the original question, the "does" bears more weight.
Have at it folks, you now have a lot to work with[8D] What makes this such a good question is that it presents itself so often, generally is misunderstood or answered poorly, and now there's a great opportunity for open participation in discussion and arguement. Much will be learned form the final answers, which I truly believe the participating audience will correctly answer. It may take awhile but it will be worth the ride[sm=idea.gif]
No name calling, no "stupid", "dumb", or otherwise negative affectations, and everyone starts even. I know you can do it. The winner will be everyone[sm=thumbup.gif]
Dick, Pe, just sit back and enjoy.
Old 07-28-2007 | 04:37 PM
Big_Bird's Avatar
Well, let me take a WAG.
Could it be the variations in pressure imposed on the metering (atmospheric sensing) diaphragm on the carburetor? These changes are due to air turbulence, cowl shape, air speed, attitude and probably some others that I haven't mentioned.
Old 07-28-2007 | 05:27 PM
I say it is loading and unloading of the prop in flight. The 200 rpm adjustment from peak is a good safety measure for avioding a lean run. When you are setting hi-speed needle you are putting max load on the engine because airplane is not moving. This is where you would be concerned about a lean run. I would take a guess and say at straight and level flight, the engine would have the lightest loading and therefore would actually be on the rich side.
Old 07-28-2007 | 06:29 PM
JoeAirPort's Avatar
My Feedback: (41)
ORIGINAL: chuck l
That's the glow engine method IMO. I don't do that with my gassers. What I do is lean the high needle until the engine can no longer maintain a constant RPM at full throttle. I then richen it until the RPM's stay the same (for about 5-10 seconds anyway). The thing with the "200 RPM less" method is you don't know that simply 200 RPM less than the old setting is rich enough. It might still sag in uplines. Which is how other prople set their high needles. If they sag on an upline they land and richen it. They keep doing this until it's good. Both methods work, the flying one may be a little better. The reason many of these guys in this thread are talking funny cause they're prolly burned out repeating the same thing over and over in a new thread.
I never have engine problems and my gassers pull very strong and constant verticals. I can hear a gas engine that's too lean without using a tach (on the ground). The RPM's slowly drop and it sounds "weak" or "anemic". It's not that difficult to tune actually.
Old 07-28-2007 | 07:13 PM
It's so that when you fly at night the extra fuel shoots flames out the pipes !!!!!
Old 07-28-2007 | 09:49 PM
A little nudge to head the right direction. It doesn't "sag" on the uplines. Though it may sound that way the description is incorrect
Continue gentlemen. There's been some good starts already.
Old 07-28-2007 | 10:30 PM
JoeAirPort's Avatar
My Feedback: (41)
Ahhh whatever. Not important, my engines run great.
Old 07-28-2007 | 11:08 PM
Here's my 2 cents. When the prop unloads during flight there will be an increased demand for fuel, so richening the mixture while the engine is not under load at WOT is a fairly safe way of ensuring it does not go too lean during flight.
Karol
Aww, come on Joe. I didn't mean to offend. Really , I didn't.
Old 07-29-2007 | 06:00 AM
I have a 10yr old weedeater with a Walbro carb, much the same engine as on my GS Warbird. Ten years ago I yanked the cord and fired it up...
Ten years later I yanked the cord and fired it up. Now, when I go after the weeds, this puts a load on the engine.. sometime it's hot and humid, sometimes cool and dry... Far as I can tell, it runs just the same as ten years ago....
Now, how did those fellas know how to set that carb for my ten year run? Did they check for sag in the high weeds??
Old 07-29-2007 | 07:51 AM
mrbigg's Avatar
My Feedback: (21)
I really think that you have to know how to read sparkplugs also. After setting the needles, fly the plane and read the plugs. You can learn alot from how the plug looks. This is what we used to do back when we were racing motorcross.
Old 07-29-2007 | 11:01 AM
JoeAirPort's Avatar
My Feedback: (41)
ORIGINAL: Silversurfer
Thanks man......we're good.
Old 07-29-2007 | 12:08 PM
Jake Ruddy's Avatar
My Feedback: (40)
How about the change in the density of the air as you go higher..
