Good way to store an engine
Old 07-29-2007 | 10:57 AM
Default Good way to store an engine
I have a new 3W-157. The plane will not be here for few months, and I need to sore me engine. Here is what I did--please let me know if I missed anything.
I put a tablespoon of 2-cycle oil into the spark plug holes, rotated is few times to coat everything and put the plugs back; attached headers and sealed all orifices (exhaust and intake) with plastic bags and scotch tape. I also put a piece of gas line on all carb tubes and plugged the holes to make everything airtight.
Engine is stored indoors in a dark place at room temperature.
Am I forgettign anyhting?
Old 07-29-2007 | 12:28 PM
Default RE: Good way to store an engine
You are good till the wife or girl friend decides on having a yard sale. Store it out in the open where you can keep an eye on it. Evan better yet send it up here where it's a lot drier.
Old 07-29-2007 | 03:52 PM
Agreed. But DO watch out for that yard sale. Especially if she has found out what the engine set you back and wants to do some revenge spending... My house has a lower density altitude than Altavillan's. Sending it here would be a better option...for me
Old 07-29-2007 | 09:27 PM
Thanks guys. Fortunately, a yard sale is unlikely--engine is in my workshop's closet. After a aouple of 'incidents' with a power tool and a battery short (no fire, thankfully) my better half is basically scared to go there .
Old 07-29-2007 | 10:08 PM
Let u sknow how you set that up to where damage was minimal and still worked well enough to scare her away from the shop. I need somthing better than the 10 rattlenakes I had loose in mine... She scared 9 of them stiff into rigor mortis the other day Only one left and he's doing poorly.
Old 07-29-2007 | 10:46 PM
tmproff's Avatar
They're usually much more afraid of spiders than snakes....
Old 07-29-2007 | 11:46 PM
No fear, she owns a pet sitting business and nothing gets turned away. Ceptin' the husband
Old 07-30-2007 | 01:31 AM
Rcpilot's Avatar
My Feedback: (78)
ORIGINAL: Silversurfer
Try shaving less often. Makes ya look rough around the edges, and if ya batt your eyes just right--sometimes can evoke sympathy and TLC.
Old 07-30-2007 | 09:37 AM
It was luck-can't take the credit for it . She was (allegedly) looking for a tool, stepped on a 3S Li-Po that was charging on the floor in a ceramic bowl, ripped it off from the charger (leaving the plug in the charger!!!) and kicked the battery rolling. In the process, it shortened the newly-exposed wires on something and created quite a spectacular lightning bolt in a dark closet. Lot's of noise, too. Fortunately, the battery kept rolling and the short was momentary.
To this day, I do not know what she was looking for and why the light was out in the closet.... In any case. I spent the first 10 minutes explainign that this was not a booby-trap designed to keep her out and the secont 10 minutes giving a gentle but firm lecture on how it may be imprudent to mess with things that can cause fire.
Worked so far....
Oh, and the battery is still operational...
Old 07-30-2007 | 10:42 AM
I'll have to try that... The looking around in the dark part was troubling.
