help with over heating carb
Old 03-12-2003 | 06:10 AM
Default help with over heating carb
I need a carb manifold that bolts straight through with out a pump hole.I was going to make one but I think it would be easier to bolt one on, like one that may go to something else.the carb is standard walbro but a big bore for a 60cc .what do you think will work and what is it to?
Darin
Old 03-12-2003 | 06:40 PM
My Feedback: (16)
I am confused. How will the lack of a pump hole keep the carb from overheating?
Old 03-13-2003 | 01:20 AM
I do not have a manifold now just metal to metal and the pump hole does not need to be there because it has a taped case for pressure.
Darin
Old 03-13-2003 | 04:13 AM
Go to your local saw shop with the carb. Doesn't matter if it has a hole or not. they'll probably give you one off an old junker if you tell them what it's for.
Old 03-13-2003 | 06:34 AM
I called a plastic shop in portland and they had some phenolic in 1/2 inch thickness so I made one from that ,I dont know how it will hold up to the fuel but man, there is no heat transfer anymore,I mean zero,nada, zilch.
Darin
Old 03-13-2003 | 06:42 AM
Default overheating carb
bn120
well now you know why you see what is sometimes called an
"intermediate flange" and the phenolic will work fine.
